http://www.blum.com/au/en/01/20/30/
Well wasn't I in for a shock when I turned up for our cabinet walk through yesterday and discovered our cabinetmaker has switched to Grass hinges instead of Blum! I'm happy with Grass of course, just upset that my soft close plans have been foiled!! SO my question is does anyone out there have any ideas for an alternative? I would prefer NOT to use the universal door dampers like the Blumotion one from Blum or Unisoft from Grass if I can avoid it simply because I think they look too obvious and "added on". If I can't find a hinge attachment alternative I'll probably just not worry about it at all
![Sad ::sad::](./images/smilies/Sad.png)
I found the following link below that might be something but am a bit confused?? Does this attach to the existing standard Grass hinge already installed? If so that's exactly what I'm after! If it does is it easily attached and where can I find a supplier?
http://www.mcfeelys.com/product/MP-SC180/Grass-ACC-Soft-Close
Any help is greatly appreciated!! Thank you!!
