Browse Forums Kitchen Corner Re: Sealing Floor Tiles 21Sep 24, 2008 5:38 pm Yes, I guess I can ask Di Lorenzo. But I think it'll be waste of time, since we live in the shire & they're located in Castle Hill. It's worth a shot anyhow.
Thanks Michelle. Edit : Sorry Michelle, didn't read that properly. I read 'your tile supplier ' instead of 'a tile supplier '. Yes, I can talk to a supplier down here Would make sense, wouldn't it ? Duh ! Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Sealing Floor Tiles 22Sep 24, 2008 5:39 pm Don’t you have a supplier near you? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Sealing Floor Tiles 24Sep 24, 2008 5:45 pm Southies, are you in the sticks!
Kidding. Oh well, just ring then. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Sealing Floor Tiles 26Sep 24, 2008 6:05 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Sealing Floor Tiles 28Sep 25, 2008 6:05 pm Sealing grout you will want a penertrating sealer we use Aqua mix sealers choice gold it is water based or pro solve which is a solvent base it does not matter if it is water base or solvent base they are just the carriers.
When you apply it to the grout only you will need to buff of the excess using a bath towel do two coats and you done remember clear seals for grout only last 5 years or so depending on maintenance and chemicals used not 15 years as some companies say. If you want something that lasts for over 10 years than grout colour sealing is the best option it is a topical coat and you have many colours to choose from. Stay away from any hardware stores that sell the cheapo stuff also clears sealers sit just under the surface to stop deep staining you may still find that it will stain on top but not colour sealing as it sits on top hope this helps as we seal grout everyday. Re: Sealing Floor Tiles 30Sep 26, 2008 6:40 am Yes there are many but try this guy he is a great operator
Stephen Rybec Cleaning Solutions- 0412 517 086 Sydney Craig Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1780 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9603 |
