Browse Forums Kitchen Corner 1 Oct 22, 2012 9:57 pm I have just seen our kitchen fitout prior to PCI next week and noticed that our oven and microwave (with trim) are sitting proud of the drawers next to them, and in the case of the microwave of the waterfall end running along side it. They stick about 5mm out. I was under the assumption these would be flush with the rest of the cabinetry. Is this normal? Does anyone else's ovens sit proud? Should this be something I request they fix up during PCI? Thanks! Oven fitting - sit proud or flush?? 2Oct 22, 2012 10:44 pm Ours sits about 5mm proud too. Never been an issue and hardly noticeable here. It's basically just the thickness of the oven door that sticks out The road to success is always under construction House completed April 2011 - slowly making it a home... Re: Oven fitting - sit proud or flush?? 3Oct 23, 2012 5:56 am Leighlou I have just seen our kitchen fitout prior to PCI next week and noticed that our oven and microwave (with trim) are sitting proud of the drawers next to them, and in the case of the microwave of the waterfall end running along side it. They stick about 5mm out. I was under the assumption these would be flush with the rest of the cabinetry. Is this normal? Does anyone else's ovens sit proud? Should this be something I request they fix up during PCI? Thanks! Unfotunately yes. Your kitchen doors are 18mm thick and alot of oven doors are 20-23mm thick. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Oven fitting - sit proud or flush?? 4Oct 24, 2012 9:19 am Thanks for that Zarli and CEK! Makes me feel better now. They are going to look into the microwave for me as they said that that should be sitting better than it is, so I think it'll all work out! Thanks again. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3260 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 691 |
