Browse Forums Kitchen Corner 1 Oct 10, 2012 8:47 pm Is 90cm between the oven and the benchtop enough space to move in the kitchen? We are putting in a 60cm Miele oven - Because we are having an L shaped kitchen with an island bench and the oven is going at the end of the L shape - there is a 90cm space. We have 1.4m space between the island and the kitchen - is that too much? I hope I have made sense! Thanks Re: Kitchen Question 2Oct 11, 2012 6:21 am 900mm is a bit narrow. I normally say 1050mm is the minimum space. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen Question 3Oct 11, 2012 1:53 pm Agree, I wouldn't go under a 1000mm. 900mm is doable, but just a little too tight. It will be difficult to stand in front of your oven with the door open. Hope this helps With 25 years kitchen experience and a passion for what I do, I have joined this forum to offer advice or at least my opinion on all things relevant to kitchens. I was a cabinetmaker by trade and am now a senior manager of a kitchen company. Re: Kitchen Question 4Oct 11, 2012 3:08 pm We have 900 at the end of the island then we have a wall. It is tight but it is doable. We don't have an oven opening though. We have 1300 between main bench and length of the island. That is ample, ..2 can pass easily, so 1400 is heaps. If you can't move your island down a bit, then it will be ok, but if you can..do it! You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9979 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 1 13128 |
