Browse Forums Kitchen Corner 1 Sep 25, 2012 11:29 pm Just designing our vanities and kitchen. With a 20mm stone top and a 40mm lip along the front - how far back (under the top) does the 40mm extra bit go? We are just looking at the amount of stone top we need in front of the vanity basins in order to allow for the lip and the door and the frame as our basin is undermount.... Thanks Re: dimensions of 40mm stone bench lip 2Sep 26, 2012 10:19 am With a standard 20mm overhang the 20mm doubling strip is usually around 60-80mm wide. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: dimensions of 40mm stone bench lip 3Sep 26, 2012 10:36 am THANKS - Will have to look at the amount of space we thought we needed in front of the basin now.... Re: dimensions of 40mm stone bench lip 4Sep 26, 2012 11:18 am chatterbox THANKS - Will have to look at the amount of space we thought we needed in front of the basin now.... Please be aware though that the doubling strip can be size you want. You also need to know the benchtop overhang, door thickness and if there is any internal cabinet rails as the bowl needs to go behind all of this. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: dimensions of 40mm stone bench lip 5Sep 26, 2012 11:37 am thanks for that ...we have allowed for frame of cabinet, door and then the overhang....all in front of the sink. Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7526 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6726 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5667 |
