Browse Forums Kitchen Corner Re: Indamatic soft close drawer add on 2Sep 26, 2012 10:26 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Indamatic soft close drawer add on 4Sep 27, 2012 7:33 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Indamatic soft close drawer add on 5Sep 27, 2012 1:37 pm For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Indamatic soft close drawer add on 6Sep 27, 2012 4:14 pm Mclaren kyton Wonder if they would work on metal sided drawers? Our cabinet maker doesn't use Mdf / particle board sides, ours all have metal sides. We're the same - would love to get some soft cloers though - let us know if you get them Chip and how they go.... Hi Kyton Ordered two units the other day from ebay and will try and document how the install goes. Given the lack of feedback, I'm assuming not many people are using this to retrofit into existing kitchens. I found out from the builder that our kitchen (currently in fixing stage) uses Hettich hinges so I've ordered two blum blumotion clips to test. Brad Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3312 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9616 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110559 |
