Browse Forums Kitchen Corner 1 Sep 19, 2012 4:31 pm Hi All, Just looking for a bit of advice. I'm currently renovating my kitchen and wondering if i should invest the money into stone benchtops or if there is a similar product out there I could look at. Just concious as this is not a dream home and my kitchen was only $2500 and stone is looking at $2800. Thank you in advance jenjen Re: Bench tops........ 2Sep 19, 2012 4:44 pm just a thought..and you might hate it, but I used laminex/ formica but did them 100mm thick. awesome. cost about $300 more than a 50mm all up ( a bench and a breakfast bar) but looks solid and grounds the kitchen. really happy with it, and sure..everyone loves stone but if you dont have the money..you dont have the money. (ours would have been about $6000, but I spent $1700 instead) Re: Bench tops........ 3Sep 19, 2012 4:44 pm IMHO I dont think its worth putting in stone thats worth more than the whole kitchen.. if you like the stone look, you can get laminate bench top with stone look finish.. i think kiwi said it better.. Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: Bench tops........ 6Nov 13, 2012 9:06 pm kiwi just a thought..and you might hate it, but I used laminex/ formica but did them 100mm thick. awesome. cost about $300 more than a 50mm all up ( a bench and a breakfast bar) but looks solid and grounds the kitchen. really happy with it, and sure..everyone loves stone but if you dont have the money..you dont have the money. (ours would have been about $6000, but I spent $1700 instead) Hey Kiwi was checking out your thread but got all confused. Do you have any pictures of the benchtop? Thanks heaps jenjen Re: Bench tops........ 7Nov 14, 2012 5:43 am Confused....now there is a word I hear a lot around me!!! Page 139 has some pics viewtopic.php?f=31&t=35307&start=2760 And here is one too...I have a swirly gloss on the breakfast bar and Matt burnished wood at the back Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hadn't seen anyone use the swirly , I just liked it on the laminate sample on line, Can always cover it with more laminate later, when I'm bored Re: Bench tops........ 9Nov 24, 2012 7:11 pm thank you! it was through laminex they have these http://laminex.com.au/products.php#!/sp ... s/view-all or http://www.thelaminexgroup.co.nz/pdf/pr ... inside.pdf this is mine http://laminex.com.au/products.php#!/sp ... l-espresso and it is also in white and black http://www.kitchenbenchtops.com/popup.p ... =163&w=&h= I can always cover it in more laminex later... Re: Bench tops........ 10Nov 26, 2012 12:25 pm Definitely go for laminex with that budget. You can get the flecked appearance to make it look like stone. ours cost $700 instead of $2500 for stone! That money can go towards better components for the other parts of the kitchen. Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11674 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31248 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3793 |
