Browse Forums Kitchen Corner Re: Laminate converted to 2pac 2Sep 11, 2012 2:51 pm Are you willing to do any of the work yourself?? You could pull the old doors off and fit the new doors which would save you alot of money! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate converted to 2pac 4Sep 11, 2012 4:05 pm All panels should be replaced at the same time. Yes they are not that hard to remove. You might have trouble finiding someone to do the job. Most cabinet makers and kitchen companys wont do it unfortunately. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laminate converted to 2pac 5Sep 12, 2012 7:54 am Please consider: Lets say you replace all the doors of your kitchen to 2 Pack hi gloss, you got past all the panel issues, kickers, infills etc. What do your benchtops look like? Are they old and dated? Are they also laminate? The reason I ask is, I've been out to peoples homes that have done a 2 part facelift. First the benchtops, which then made the doors look dated, then they change the doors & panels. This being done in 2 different stages costs you $$$$$. It's always better to start with a blank canvase. Also you wont have much choice over the kitchen design, your stuck with the old layout. I know your only asking about your doors, but if you intend on changing anything else in the future, you will lose money. Re: Laminate converted to 2pac 6Sep 12, 2012 2:44 pm People change doors and bench tops on kitchens thinking that it will save them alot of money over doing a new kitchen. It doesnt!! The doors and the bench tops are the most expensive part of a kitchen. The white cabinets are cheap as chips. If you replace a bench top on an existing kitchen you still need a sparky and plumber to disconect and reconect and you will also need a new splash back. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 4612 We are doing heaps of hybrid at the moment and the cost sits between $60-65/sqm including installation. Stairs are around $90-100 each 1 3418 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 3771 |
