Browse Forums Kitchen Corner 1 Aug 11, 2012 8:21 pm We have recently completed our kitchen but as yet we dont have our pantry door on. Our plans stipulated inward opening, integrated door, so I have a door but the cabinet maker is at a loss as to what hinge to use. Someone on H1 showed me he kitchen with a hafale hinge, that was in the floor, however apparently that is for a normal door, not a laminated door(ie same thickness as the rest of the kitchen), they were going to use a piano hinge, but that doesnt allow me to get out. Can any experts send me in the right direction to get a hinge that will allow the door to open both inwards and outwards. Thanks Re: Inward opening pantry door 3Aug 11, 2012 11:26 pm seriously now. . . hmmm. . . could they use the 180 degree door hinges? Though how would you make it stop in the middle? It's a challenge! Let me think about it (i.e. I will now go to bed and completely forget about your conundrum Gabs. ) Re: Inward opening pantry door 7Aug 12, 2012 8:04 am jodge Just use the piano hinge and make sure you have the pantry well-stocked with wine. . . Maybe Bear Grylls has done something on escaping from a walk in pantry? What about those door hinges they use in hospitals, where they go both ways depending on which way you're entering? Built the Seaview 36 with Rawson Homes - Read about it on my blog http://lamaisondemorgan.blogspot.com.au/ Re: Inward opening pantry door 8Aug 12, 2012 8:50 am Good point smorgzz. Just keep your phone with you when in the kitchen, so you can call bear for advice. How about commercial toilet door hinges, where there's a slope. The door naturally swings closed. Re: Inward opening pantry door 9Aug 12, 2012 9:45 am jodge Just use the piano hinge and make sure you have the pantry well-stocked with wine. . . +1 and cheese and crackers Re: Inward opening pantry door 11Aug 12, 2012 9:49 am jodge excited jodge Just use the piano hinge and make sure you have the pantry well-stocked with wine. . . +1 and cheese and crackers Probably a bucket and some loo-roll too. I was thinking the same thing but then thought the little room might not ever be used again as a pantry, it could become the hidden room for those times you just need to hide from the world Re: Inward opening pantry door 13Aug 12, 2012 9:53 am smorgzzz jodge Just use the piano hinge and make sure you have the pantry well-stocked with wine. . . Maybe Bear Grylls has done something on escaping from a walk in pantry? What about those door hinges they use in hospitals, where they go both ways depending on which way you're entering? I was thinking restaurants but the same thing. Why can't they use for you whatever they use here?? Re: Inward opening pantry door 14Aug 12, 2012 11:59 am Thanks guys, very useful info as usual...NOT In regards to the piano hinge, we can have a handle on the inside, but because I dont want a handle on the outside, it means I have nothing to pull on to close it from the outside. The other hinges used in hospitals etc would be similar to the hafale hinge I have seen however they are for normal thickness doors, not a standard kitchen(laminex door) The cabinet maker suggested a shadow line the whole length of the door, similar to the handleless shark tooth drawers but sideways, I may have to end up with that, but would have preferred that the door was completely flush. Hoping one of the kitchen experts may have some idea! Re: Inward opening pantry door 15Aug 12, 2012 2:17 pm greenfish smorgzzz jodge Just use the piano hinge and make sure you have the pantry well-stocked with wine. . . Maybe Bear Grylls has done something on escaping from a walk in pantry? What about those door hinges they use in hospitals, where they go both ways depending on which way you're entering? I was thinking restaurants but the same thing. Why can't they use for you whatever they use here?? Wouldnt work. Almost all these type of hinges are made for full thickness doors not 18mm cabinet doors. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Inward opening pantry door 16Aug 12, 2012 2:18 pm gogo65 We have recently completed our kitchen but as yet we dont have our pantry door on. Our plans stipulated inward opening, integrated door, so I have a door but the cabinet maker is at a loss as to what hinge to use. Someone on H1 showed me he kitchen with a hafale hinge, that was in the floor, however apparently that is for a normal door, not a laminated door(ie same thickness as the rest of the kitchen), they were going to use a piano hinge, but that doesnt allow me to get out. Can any experts send me in the right direction to get a hinge that will allow the door to open both inwards and outwards. Thanks Is the door hinged to a kitchen cabinet or is it hinge to the wall?? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Inward opening pantry door 19Aug 12, 2012 8:33 pm Ok personally I would use saloon style door hinges that swing both ways. You would need to use thicker doors around 32mm thick. You can get MDF that thick and have it spray in 2pac. or you could set two doors back 600mm from the front edge and have them open out. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5248 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44117 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1761 |
