Browse Forums Kitchen Corner 1 Jul 25, 2012 9:35 pm Anyone knows what's the rule for the height between rangehood and hot plate? Because my the ceiling is 28c (2400mm) and height of rangehood to hot plate is 686mm. I don't want the overhead cupboards looks too long (770mm) so I am thing it may ajust the height of rangehood? Re: rangehood height 2Jul 25, 2012 10:57 pm I went by the recommendation of my rang hood manufacturer (Qasair), which was 700-800mm above the cooktop. Being a tall guy, I went with 800 so that I don't bump my head into it. That said I've got 3.2M ceilings to work with, and no upper cabinetry to worry about. You need to factor all these things in my house blog: http://sugarloafdrivebuild.blogspot.com/ Re: rangehood height 3Jul 26, 2012 7:57 am murphywei Anyone knows what's the rule for the height between rangehood and hot plate? Because my the ceiling is 28c (2400mm) and height of rangehood to hot plate is 686mm. I don't want the overhead cupboards looks too long (770mm) so I am thing it may ajust the height of rangehood? Do you have cornices? If so what height are they? What sort of cooktop do you have? What recomendation does your rangehood manufacturer make for the space above cooktop. All of the above is required to give you and informed opinion. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: rangehood height 5Jul 31, 2012 6:14 pm murphywei Anyone knows what's the rule for the height between rangehood and hot plate? Because my the ceiling is 28c (2400mm) and height of rangehood to hot plate is 686mm. I don't want the overhead cupboards looks too long (770mm) so I am thing it may ajust the height of rangehood? My overhead cupboards are 910mm down from the corniche and look very good. I would not want to have the cupboards close at the rangehood if the rangehood just covers the same width as the cooktop. ok thanks - yes was wondering if that should have been listed as Option Three! 2 7755 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9570 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16026 |
