Browse Forums Kitchen Corner Re: Height for Kitchen Ceiling and splash back 2Jul 23, 2012 1:12 pm 28what ??? Standard ceiling height is just over 2400mm Standard splashback height is 600mm but you need to consider what sort of rangehood you have. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Height for Kitchen Ceiling and splash back 3Jul 23, 2012 2:12 pm CuttingEdgeKitchens 28what ??? Standard ceiling height is just over 2400mm Standard splashback height is 600mm but you need to consider what sort of rangehood you have. Hi CuttingEdgeKitchens, it's 28c brick size. Do you mean standard/minimum ceiling height for Kitchen is 2400mm (25c)? Can I go higher than 2400mm? Re: Height for Kitchen Ceiling and splash back 5Jul 23, 2012 5:02 pm No, standard ceiling height in all rooms is just over 2400mm. You can go higher and some people do, but it cost more to do it. Kitchens are not always lower than living areas. All my living areas, bedrooms and kitchen ceilings are the same height! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Height for Kitchen Ceiling and splash back 8Jul 24, 2012 5:28 pm Do you have cornices? If so what height are they? Are you going gas or electric cooktop? We need all the info to be able to give you exact answers. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15309 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6933 Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 |
