Of course, you onlyneed to spend more moneyon starfire glass if you want a white splashback. Otherwise, jsut look at your proposed colour through normal glass and adjust accordingly.
One day, someone will make a lot of money out adjusting paint colour by subtracting the right amount of green so that it appears the same as if starfire glass is used. Why paint starfire glass when you can make an adjustment to the paint. Of course, white and some other very light colours will not work.
Demolition August 2009, Construction Started September 2009, Completed December 2010
Cookie - I was just about to say that kitchen is stunning!! I am also going for an all white kitchen, however, was thinking of using a silvery/grey or light brown splashback, now I'm rethinking if it's better to go all white
The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work.
You might…
Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick…
