Advice on kitchen sink
I wanted a double undermount sink and it was suggested that we get an Oliveri Sonetto sink. I've googled till I can google no more and it seems that the sink I've been recommended is 2 individual sinks rather than 1 double sink undermounted.
I'm hoping someone out there may be able to shed light on this before we get to the point where a sink I really don't want gets put in.
Second time builder very frustrated.
K
We are about to start building our home and have done our selections but I'm now questioning the choice of sink we have.
K
K
Deponds on what style has been ordered.
Sonetto double undermount sink style 1063u, same size 33L
Sonetto double undermount sink style 1073u, 38L + 33L
Hope that puts your mind at ease.
http://www.oliverisinks.com/downloads/specs/individual/1050U.pdf
And you can match it with the smaller one:
http://www.oliverisinks.com/downloads/specs/individual/1030U.pdf
Unlike the 1073U, these two are two separate bowls but they will line up perfectly and you can put them any way you like.
I think Oliveri also has a bigger sink in their Sonetto range:
I might be confused on this, but I got the impression that the OP (kyli093) wanted an integrated double sink, not two seperate sinks put next to each other??? She's concerned that two single sinks were ordered instead of a double sink ....
Pete_n_Pet has it right. I'm really looking for a double bowl (not two separate bowls) and just want confirmation that the oliveri sonetto is a double bowl and not two singles. ie, there should be a stainless steel join between the two bowls making it a double. If there is bench between the two bowls this would mean it is two separate bowls.
can they tell you what sink style number has been ordered? This will let you know if it's double or two singles.
http://oliverisinks.com/au/sonetto.cfm
The website shows 2 single bowls (model 1030u) side by side.
It's a very nice sink. We were initially going to go with the professional series but it was just a little to large and much more expensive, the Sonetto has a very similar look without the price tag.
We have the Sonetto double bowl sink model 1063U
Sorry about the confusion. Oliveri Sonetto sink range has either single or double bowl sinks so it really depends on which model they've ordered for you. Here's the full range of Oliveri Sonetto sinks:The website shows 2 single bowls (model 1030u) side by side.
2
Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.…
18/02/2024
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
7/08/2023
5
I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I…
