Browse Forums Kitchen Corner 1 Mar 23, 2012 9:04 am Currently I have a 600mm bulkhead over my overheads which are 450mm. IN the 150mm overhang I have downlights which look really good. In the new house plan the O/H's are also 450mm deep and they have planned the bulkhead to be 450 as well so they will both be flush. Is this going to look a bit weird? I cant say I have been paying attention in the display homes as to whether or not this is the norm now. Also I have a bench area that runs adjacent to my main bench and island bench - this is also recessed - should I have a bulkhead over this as well or will it not look right as the recess is on an inside wall. Any suggestions would be grea thanks Re: Kitchen bulkhead question 2Mar 23, 2012 5:26 pm Most bulkheads are actually flush with the cabinets. They have been done this way for years. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen bulkhead question 3Mar 24, 2012 10:32 am thanks cuttingedge - so if thats right then where do the downlights go? Just in the ceiling? cheers Re: Kitchen bulkhead question 4Mar 24, 2012 10:38 am auds thanks cuttingedge - so if thats right then where do the downlights go? Just in the ceiling? cheers Yes, with all the other downlights. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen bulkhead question 5Mar 24, 2012 11:15 am or you put a few downlights in a fake bottom of your overheads (task lighting) 2010, June : Land bought (1700sqm, battleaxe block). That's it so far! We're in the design phase .... You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13125 |
