Browse Forums Kitchen Corner 1 Mar 01, 2012 8:30 am I paid tons of gold for this flush mounted kitchen sink, the builder initially put it as inset as they'd never seen a flush mounted sink until I got a kitchen guy to show them what a flush mounted sink looks like. So the old one out and the new one in, the problem is, the sink isn't quite flush with the bench top, it actually sits a little bit below the surface thus create a very sharp yet very rough edge in some area, if I run my finger along it, it can cut my finger easily. (see pic) Getting the builder back to do it again is out of question, they will only make it worse, also I'm in the process of taking them to VCAT for many other major issues of the house. My question is, what can be done to fix it other than replacing the bench top? I'm happy to pay to fix it. Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: Flush mounted kitchen sink not really flush, what can we 2Mar 01, 2012 9:36 am Is it in stone or laminate If its stone you could get them to polish/grinds the sharp edge and smooth it off. If its laminate I doubt you'll get a better fit. Laminate doesn't like to form around edges that have small radius' and it would require a lot of work to get right. Likely at your cost. Re: Flush mounted kitchen sink not really flush, what can we 3Mar 01, 2012 12:19 pm Its stone. As chrisandkate said have an arris put onto the sharp edge. The sink will have to come out to do this but it will make it much better. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Flush mounted kitchen sink not really flush, what can we 4Mar 01, 2012 2:50 pm Thanks Chrisandkate and CEK. Yes it is stone. Another question, is this a stone mason's job or I need the plumber as well to remove the sink? Built: Modified H3nl3y S0h0 Q1 in Melbourne :- Never again Re: Flush mounted kitchen sink not really flush, what can we 5Mar 01, 2012 7:34 pm EmeryBB Thanks Chrisandkate and CEK. Yes it is stone. Another question, is this a stone mason's job or I need the plumber as well to remove the sink? Technically you need a plumber but most stone masons should be able to disconect the waste pipe. The tap doesnt need to be disconected which makes it an much easier job! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28260 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15773 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72331 |
