Browse Forums Kitchen Corner 1 Feb 29, 2012 7:13 am Hi guys, I would like to replace my old kitchen bench tops,(old 50x50mm tiles from the 70`s), with some Tassie Oak floor boards. I would like to put Granite on, bit it is a little bit out of my budget. If I put a 2 pac polyetheline finish on top, will that be able to handle plates with hot food and hot coffee mugs without burning or ringing? I understand that hot pots/pans from my cooktop and oven will burn the surface, or should I be looking at something else to finish the benchtop? Thanks. Re: Kitchen bench tops 2Feb 29, 2012 6:07 pm NOOOOOOOOOOOOOOOOOOOOOOO dont do it. Polyurethane should not be used as a bench top FULL STOP. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen bench tops 3Feb 29, 2012 8:41 pm CuttingEdgeKitchens NOOOOOOOOOOOOOOOOOOOOOOO dont do it. Polyurethane should not be used as a bench top FULL STOP. What CEK said If you are wanting to put hot items on then either get some heat proof boards or get some nicer modern tiles for the benchtop. A bank is a place that will lend you money only if you can prove that you don't need it... Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11682 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31263 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3796 |
