Browse Forums Kitchen Corner 1 Feb 27, 2012 1:54 pm Hi We are temporarily living in a rental and would like to buy new or second hand a 450mm or 600mm wide pantry cupboard up to about 2M. I will then install a pull out pantry unit similar to this I assume its relatively easy for a non cabinet maker but still practical person to put in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our new home may or may not fit whatever I use here hence secondhand may be a better option if I am only going to discard it later on when we move. Can anyone recommend both new suppliers in Perth and also any secondhand or used dealers who might be clearing this type of product? DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12749 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6354 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4490 |
