Browse Forums Kitchen Corner 1 Feb 27, 2012 9:21 am We are just about to build a new home and are considering using the Dupont Simplicity benchtops as I was told it was a less expensive way to obtain a solid benchtop, but I have just been given a costing from the builder of $7100 and have baulked a little at the price. Can anyone tell me if this is a reasonable cost for two bench tops 1000mm x 2500mm and 600mm x 4000mm. We have had an issue with a costing for one of the other items for our house and I just want to make sure that we are getting reasonable quotes from the builder. Many Thanks. Re: Costing for Simplicity Benchtops? Too expensive? 3Feb 27, 2012 6:19 pm If you decided to use Caesar Stone or Quantum Quartz (etc). you're price would be considerably lower. That's 2 slabs for the two benches, one with a join through the center. Depending on the edge profile you've chosen but $7100 sounds extremely expensive. Re: Costing for Simplicity Benchtops? Too expensive? 4Feb 28, 2012 7:28 pm Thanks guys. Have just been told by the builder that this cost includes 'waterfall edges' on two ends of the island bench, which makes me feel a bit better about the price. Will definitely investigate the Ceasar Stone option though.. Re: Costing for Simplicity Benchtops? Too expensive? 5Feb 29, 2012 6:35 am Still sounds very expensive! In Caesarstone you should expect to pay around $4000-$5000 Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Costing for Simplicity Benchtops? Too expensive? 6Feb 29, 2012 9:50 pm With panels it's still 3 slabs RRP for three slabs STD range is $2613.00 ($4487.00 in labour) and DEL is $2967.00 ($4133.00 in labour) seems quite excessive. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8245 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5633 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2503 |
