Browse Forums Kitchen Corner 1 Feb 19, 2012 2:36 pm Does anyone know what the Absolute Quartz is? It's Q-stone or not? How about it compare to Essa Stone? Also the builder provides it for kitchen and bathroom are all 20mm thickness. I am thinking may I use 30mm stone with waterfall end in the Kitchen and the rest of use 20mm to save the cost? The 20mm stone is easier to crack than 30mm one or it is strong enough to use? I will much appreciate if anyone gives the suggestion. Re: Stone Benchtop 2Feb 19, 2012 3:09 pm 20mm is more than strong enough its only a looks issue. I personally dont like 20mm in a kitchen, I prefer 40mm. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12929 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7508 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 |
