Browse Forums Kitchen Corner 1 Feb 18, 2012 7:57 pm Hi all, Finally my kitchen has started going in, and I've reached the point where I can put up my canopy rangehood, but I'm unsure what the best way is to secure it and support its weight. The mounting plate only has two screw holes, one on each side. I'm pretty sure the left one is going to line up nicely with a wall stud, however the right one will only have plasterboard behind it. Should I just use a heavy duty plasterboard anchor on this side?? Or do I have to go to the trouble of securing a piece of timber between the studs? I really don't want to have to patch up plaster.... Not 100% sure of the weight of the hood; it's an Asko glass canopy rangehood. Thanks in advance Forum folk! 4 9048 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8302 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4517 |
