Hi,
Can someone tell me if you can get Ocean Foam in 40mm thickness? On the caesarstone website I can only see 20mm http://www.caesarstone.com.au/Colours/C ... m%E2%84%A2
Thanks
Scott
Browse Forums Kitchen Corner 1 Feb 17, 2012 9:32 am Hi, Can someone tell me if you can get Ocean Foam in 40mm thickness? On the caesarstone website I can only see 20mm http://www.caesarstone.com.au/Colours/C ... m%E2%84%A2 Thanks Scott Re: Ocean foam - caesarstone 4Feb 17, 2012 10:52 am They only double the thickness at the edges that are exposed, and the remainder sits on a 20mm MDF substrate. As such, it's no where near double the amount of material required. The additional cost comes from the small additional quantity of material for the edges and the additional labour associated with making the laminated edge. Re: Ocean foam - caesarstone 6Feb 17, 2012 1:31 pm All Caesarstone colours come in 20mm and some come in 30mm. Caesarstone doesnt actually supply a 40mm product. The join two 20mm pieces together. It is usually only the front edge that is thickened. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Ocean foam - caesarstone 7Feb 17, 2012 2:12 pm Hi Sco77k, Good stone masons will mitre the front edge rather than sandwich two pieces together. This eliminates seeing a join, which in some colours can be quite prominent and other just a faint line. Ask your kitchen company how their stone mason does their 40mm stone, sandwich or mitre the front edge. Hope this helps With 25 years kitchen experience and a passion for what I do, I have joined this forum to offer advice or at least my opinion on all things relevant to kitchens. I was a cabinetmaker by trade and am now a senior manager of a kitchen company. Re: Ocean foam - caesarstone 9Feb 17, 2012 2:25 pm CuttingEdgeKitchens All Caesarstone colours come in 20mm and some come in 30mm. Caesarstone doesnt actually supply a 40mm product. The join two 20mm pieces together. It is usually only the front edge that is thickened. I still need another quote.. I'm in Ryde Re: Ocean foam - caesarstone 10Feb 17, 2012 8:24 pm MrZebra They only double the thickness at the edges that are exposed, and the remainder sits on a 20mm MDF substrate. As such, it's no where near double the amount of material required. The additional cost comes from the small additional quantity of material for the edges and the additional labour associated with making the laminated edge. for 30mm stone - do they still have mdf substrate underneath or not Re: Ocean foam - caesarstone 11Feb 18, 2012 3:08 pm Kitchenpro Hi Sco77k, Good stone masons will mitre the front edge rather than sandwich two pieces together. This eliminates seeing a join, which in some colours can be quite prominent and other just a faint line. Ask your kitchen company how their stone mason does their 40mm stone, sandwich or mitre the front edge. Hope this helps I wouldn't say "good stonemasons mitre the front edge". Mitred edge and laminations are both done exceptionally well at our company. Mitring edges are usually done on 50mm or more edges, but 40mm is becoming more and more popular as a mitred edge. It is in turn more expensive than lamination. The join would only be "quite prominent" if the stonemason doesn't have the right glue colour or they haven't buffed the edges well enough in all of the different roughnesses. A faint line should be the most you'd ever see. Re: Ocean foam - caesarstone 12May 23, 2013 4:30 pm kmcgreg I think they just join two 20mm layes together - it looks seamless. I am getting the same stone. Just need to find a white vinyl to match. I know this is an old post but jsut wondering if you ended up using the Ocean Foam and if so which white vinyl did you go with?? Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4148 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2427 |
