Browse Forums Kitchen Corner 1 Feb 11, 2012 10:25 pm Hi All Just a quick question that I am hoping someone can answer. With the squareform benchtops where the laminate is rolled over the edge not where you have the seam line along corner of the bench are Laminex the only ones that do this style or can you use any brand of laminate like Formica or Polytech and still get the same squareform result. I have added a pic of the style I am asking about. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Re: Squareform Bench Edges 2Feb 11, 2012 11:15 pm I deal with laminex and I know that formica (part of laminex) can also be square formed. I assume that all post forming laminates can be square formed, so the polytech should be the same. As you are in WA, give Proform a call. They do the post forming for Laminex (Formica) and can do most things you may need. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Squareform Bench Edges 3Feb 12, 2012 9:22 am Thanks Chippy, I was hoping that was the case. Will give proform a call on Monday and confirm. Re: Squareform Bench Edges 4Feb 12, 2012 3:25 pm chippy I deal with laminex and I know that formica (part of laminex) can also be square formed. I assume that all post forming laminates can be square formed, so the polytech should be the same. As you are in WA, give Proform a call. They do the post forming for Laminex (Formica) and can do most things you may need. Sorry but thats not right. Laminex put out a specific range of laminates that can be square formed. I think there are only about 15-20 laminex laminates that are available to be square formed. The standard post formed round is a 9mm radius while the square form radius is 5mm. The laminate used for square forming is alot thinner than standard laminate. Unfortunately not all laminates can be square formed only a few can be. I am not sure about formicas range though. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Squareform Bench Edges 5Feb 12, 2012 4:23 pm @ CEK, I'm fairly close. 31 laminex colours and 97 formica colours can be tight formed. The formica can't be formed quite as tight (7mm) as the laminex (5mm) however it still has the same square edge look the op is after. As I mentioned I have my account with laminex so usually just deal with them, however I assume that most laminate suppliers will have similar post forming products that allow for tight radius bending. You probably know more about the other brands though as I'm not exclusively a cabinet maker, just a chippy that can build cupboards. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Squareform Bench Edges 6Feb 12, 2012 5:39 pm But laminex has far far more colours than 31 and these cant be square formed. The OP asked about Squareform which is a 5mm radius not 7mm or 9mm. You said "I assume that all post forming laminates can be square formed" which isnt right. The laminate has to be thin enough to be rolled around such a tight radius. Laminex has 216 listed laminates under the bench top section with only 30 or so available for squareform. Formica has a similar product called TightForm which is a 7mm radius and is available in 97 colours. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Squareform Bench Edges 7Feb 12, 2012 5:58 pm Squareform is a registered trademark of Laminex so no other laminate brand can do a Squareform bench. What the OP was asking is if other laminate suppliers can do a bench that looks similar (tight radius). As I pointed out (and you mentioned again) formica have 97 colours that can be tight formed and having had a look at the Polytec site it seems that most of their bench top laminates that can be tight formed. Whether it is 5 or 7mm the look is very similar. I think my initial response was fairly accurate, maybe I should have said that most laminate brands will have products that will give a similar look. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Squareform Bench Edges 8Feb 12, 2012 7:50 pm Thanks CEK and Chippy I appreciate your responses. I understand that Squareform is a Laminex TM but as long as I can get a similar look I will be happy with that. Just looking to get a squarish edges rather than the rolled edged or the seams along the top. But will know now that If I want the sharper square look I will have to stick with the laminiex squareform colours. Thanks guys Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11927 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31397 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3891 |
