Browse Forums Kitchen Corner Re: 300mm kitchen bench overhang with 20mm thinck stone 2Jan 24, 2012 8:07 am Our Homebuilding Thread 17th Nov - 1st meeting with PJB architect 27th Feb - Signed contract 23rd Mar - Plans approved 3rd Apr - Slab laid 18th Apr - Roof On 10th May - Lock-up 26th June - Handover Re: 300mm kitchen bench overhang with 20mm thinck stone 3Jan 24, 2012 10:06 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com 300mm kitchen bench overhang with 20mm thinck stone 7Jan 26, 2012 10:01 am Our 20mm stone bench over hangs 460mm from the cupboards but the builder installed a board underneath it do the over hang is effectively only 100mm. If you want I can take a picture and attach it. I would be concerned about a large over hang with 20mm and if we had known about the board underneath we might have gone for 40mm stone instead. You can't easily see it but I know it's there. Chatz 300mm kitchen bench overhang with 20mm thinck stone 8Jan 26, 2012 10:05 am Here is a picture of our bench: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (Changed the image link, hopefully this one works...) Henley Talise Q2 in Melbourne SE Forum, Blog 26/11 Demo, 23/1 Quote, 7/2 Colours, 11/3 Tender, 28/3 Contract, 1/6 Site Scrape, 16/6 Slab, 30/6 Frame, 4/8 Lockup, 26/8 Fixing, 26/10 Handover Re: 300mm kitchen bench overhang with 20mm thinck stone 9Jan 26, 2012 11:22 am The Caesarstone Technical Manual provides the information you want. This reference states that a 300 mm overhang is acceptable: http://www.uhny.com/pdf/caesarstone_tech_datasheet.pdf However, this reference states a 200 mm is the maximum: http://media.caesarstoneus.com/pdf/CS_TDM_0511.pdf The first reference is dated 2005 and the second dated 2010. So, when my house was being build, 300 mm overhang was allowed. I suspect conservatism has stepped in and now 200 mm maximum is recommended. In either case, I would never stand on the overhang. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: 300mm kitchen bench overhang with 20mm stone 13Jan 27, 2012 1:01 am CC101, No, there is still enough gap between the stools and the bench that you don't bump your knees. Chatz Re: 300mm kitchen bench overhang with 20mm stone 14Jan 27, 2012 6:17 am Does it make a difference if you have waterfall edge as you then have support for the 300mm overhang on each edge?? Re: 300mm kitchen bench overhang with 20mm stone 15Jan 27, 2012 9:23 pm thanks chatz. kdgirl - waterfall edge will have support only at the end. stone's manual says that any overhang more than 200mm should have some supports underneath at some regular distances. Re: 300mm kitchen bench overhang with 20mm stone 19Apr 28, 2012 6:32 pm deb17 We have 200mm overhang on ours. I have seen Henley Homes with ones that hang over much more than ours. I would say 400mm. does that henley homes with 400 overhang has 20mm stone? Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3794 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7774 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11677 |
