Browse Forums Kitchen Corner 1 Jan 23, 2012 11:25 am Hi, I am hoping to have an integrated dishwasher in our new kitchen, but I am unsure if I will be able to, due to the fact we are having shadowline cupboards and drawers, ie no handles. Every picture I have seen of integrated dishwashers has shown then with a handle. Would anyone know if its possible to have an integrated dishwasher with shadowline? Many thanks, NN Re: Integrated dishwasher help please! 2Jan 23, 2012 4:28 pm Yes it is possible. However you need to have a benchtop height of 920 at a minimium. You also need to check the lowest height of your dishwasher. I have done it many times but you do need the right dishwasher and a bench height to match. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Integrated dishwasher help please! 3Jan 25, 2012 8:04 pm Thank you so much. Can I please ask, do you ever do different heights for the island bench and wall bench? Is that a no-no? I'm sure we can have the island bench any height at this stage, but the wall bench is locked in at 900mm due to the window which will act as a spashback, if you know what I mean. Also, would a semi-integrated dishwasher have the same height requirement? Regards, NN. Re: Integrated dishwasher help please! 4Jan 27, 2012 8:12 am nicenurse Thank you so much. Can I please ask, do you ever do different heights for the island bench and wall bench? Is that a no-no? I'm sure we can have the island bench any height at this stage, but the wall bench is locked in at 900mm due to the window which will act as a spashback, if you know what I mean. Also, would a semi-integrated dishwasher have the same height requirement? Regards, NN. I have never built a kitchen with two different bench heights and I personally wouldnt do it. It really depends on the brand of the dishwasher as to the height. Integrated and Semi Integrated are around the same height. Personally I would call your kitchen company and find out the distance from the floor to the underside of the shadowline detail. You then need to reaserch dishwashers to find one that fits under this height. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com 2 2525 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2714 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7165 |
