My doors are 4 mm less than the carcass! (would have liked 2 mm less)
But then my Miele oven is 6 mm less than the carcass!!! (Don't know what would have been best for the cupboard above the oven).
Browse Forums Kitchen Corner Re: Gap between cabinet doors - normal or not? 21Jan 27, 2012 8:19 pm My doors are 4 mm less than the carcass! (would have liked 2 mm less) But then my Miele oven is 6 mm less than the carcass!!! (Don't know what would have been best for the cupboard above the oven). Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Gap between cabinet doors - normal or not? 23Jan 28, 2012 9:23 am I always measure "line of sight" That is, I look to the parallel edges beyond any rounding. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Gap between cabinet doors - normal or not? 24May 21, 2016 12:44 pm Old thread to be pulling up I know. But have question very much related to this. If you have a double door cabinet how much gap should be on the left, centre and right. Or more to the point if the cabinet is 1055mm wide how wide would you make each door? Reading above I would be saying 1, 1 and 1 meaning door width of 526, or should I go 525 just to be sure. Would then end up with 1.5, 2, 1.5, or 2, 1, 2. Re: Gap between cabinet doors - normal or not? 25May 22, 2016 1:47 pm All gaps should be 2 - 2.5mm no more no less. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Gap between cabinet doors - normal or not? 26May 22, 2016 5:25 pm A 1055mm cupboard would have door sizes as follows: 2mm gap on left, right and centre= 6mm space 1055-6= 1049÷2 doors= 524.5mm doors. That would be for a stand alone cabinet with end panels flush the door fronts. If you carried the same margins across a bank of cupboards then the gap between 2 cupboards would be 4mm (2mm on one set and 2mm on the next) this would have to be evened out to 3mm over all cupboards. If I'm building a kitchen the CNC program sets the gaps at 1.5 mm each side and 2 in the middles so the gaps are an even 2-2.5 mm across the set. Re: Gap between cabinet doors - normal or not? 27May 22, 2016 5:41 pm Thanks for the replies. I was able to push the cabinet out to 1056mm and made the doors 525 each so 2 2 2 gaps. What I have is a double base cabinet with end panels either side, then a wine fridge, followed by another 1056 double base cabinet with side panels. Wine fridge is 600mm wide but says leave a 615mm gap. I just made that 613 instead, 2mm less won't be a big issue. Especially when wine fridge makes it clear the main ventilation is over the top plus a a side vent into one of the base cabinets. 2 7535 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4872 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19245 |
