Browse Forums Kitchen Corner Re: Movement of Drawers 2Feb 18, 2008 5:51 pm I'm pretty sure you can install soft-closers to any kitchen drawer or cupboard
My parents bought a whole box from a Blum distributor and installed them afterwards After 4 years - we're in! Re: Movement of Drawers 4Feb 19, 2008 8:59 am The softclose dampers available aftermarket for doors are not really suitable for drawers - although they will work.
Blum advise against using the damper on drawers, as the load of the closing drawer is taken by the drawer front rather than in the runners. This can lead to the drawer front eventually coming lose from the rest of the drawer assembly. Blumotion softclose drawer runners and assemblies can be retrofitted to existing cabinets but it does involve replacing the entire drawer box and runner set up, as well as some very accurate drilling. Cheers Earl Re: Movement of Drawers 5Feb 19, 2008 9:21 pm nzfiona You know those IKEA kitchen drawers that close slowly for the last couple of cms? Does anyone have those type drawers in their kitchen? Fiona Yep, I had a heap of them (until I sold my house) Take a look at my contemporary kitchen design Re: Movement of Drawers 6Feb 19, 2008 9:52 pm nzfiona You know those IKEA kitchen drawers that close slowly for the last couple of cms? Does anyone have those type drawers in their kitchen? Fiona We are installing Inno Tech drawers instead of the standard range. http://www.spec-net.com.au/press/0108/het_300108.htm Re: Movement of Drawers 7Feb 20, 2008 4:41 pm we got softclosers for all the doors and the draws in the kitchen area (not the storage draws in the 'living' area. I think its money well spent gives the kitchen a very nice feel to use and you can just push and forget as you walk away.
Doors are easy hinges often can have a unit clicked on otherwise there are screwons or knock in options seperate from the screw. Draw fronts i am not so sure about you could probably use a knockin unit if you put it near where the front attaches to the runner. Wouldnt be as good as the real thing but would help. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20608 Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6955 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 7058 |
