Browse Forums Kitchen Corner Re: Movement of Drawers 7Feb 20, 2008 4:41 pm we got softclosers for all the doors and the draws in the kitchen area (not the storage draws in the 'living' area. I think its money well spent gives the kitchen a very nice feel to use and you can just push and forget as you walk away.
Doors are easy hinges often can have a unit clicked on otherwise there are screwons or knock in options seperate from the screw. Draw fronts i am not so sure about you could probably use a knockin unit if you put it near where the front attaches to the runner. Wouldnt be as good as the real thing but would help. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20580 Are they stumps or screw piles ? How much fill is there, is the site a class "P" ? A "H2" site is not supposed to have stumps it is supposed to have grid beams according… 1 6942 House movement is always a potential problem and there is a cause. Yes you should have it inspected by a competent and experienced building consultant 2 7045 |
