Browse Forums Kitchen Corner Re: Kitchen Lighting 5Jan 01, 2012 11:50 pm thebigbuild its definitely open plan, but is a big space. hmnz im now thinking similar styling but different.. like this pic where it shows 2 diff pendants? http://www.decorpad.com/photo.htm?photo ... toId=80983 Brilliant, this was exactly my thinking! Sufficiently different so that it doesn't look contrived and like you've tried to 'match' everything, but also similar so that is provides a sense of symmetry. Perfect! Now, the hard part - finding pendants that are different, but have a similar quality, to the dining pendants. Check out these guys, http://www.onlinelighting.com.au/index. ... d79e48be74 they have more pendants than you can poke a stick at! Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28820 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8822 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8587 |
