Browse Forums Kitchen Corner 1 Dec 31, 2011 1:32 pm Hi all (and happy new year!), I'm contemplating what sort of splashback/surround to have around my kitchen window, and I'd appreciate some input. As you can see in the images below, I'm having a glass splashback behind the cook top (shown in green). However, on the adjacent wall there is a large window with a 100mm gap between the sill and the benchtop (shown in blue) and the glass splashback. I would also like to have the splashback/upstand follow around the wall that is flush with the breakfast bar overhang. Of course, one option would be to have the window surrounded in the same glass splashback that will be on the back wall, however, I'm concerned that this might look a bit odd. Another option I've considered is having caesarstone around the window (to match the benchtop), or alternative go for a plain white tile. FYI I will be having white two-pack cabinets, Caesarstone Haze (very pale grey) benchtop and the glass backsplash will probably be a duck egg blue or a mint colour, and I'm thinking of having it in slumped glass to add a bit of interest. Any suggestions would be much appreciated! Thanks in advance! Re: Splashback around tricky kitchen window. 2Dec 31, 2011 4:37 pm If it is still in the pre-building stage, have the window run to the edge of your glass splashback and run the splashback into the window. Ditto the benchtop, drop the window to bench height and run the benchtop into the window. Much tidier... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Splashback around tricky kitchen window. 4Jan 02, 2012 4:52 pm Glass IMO. I dont like mixing splash backs. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7398 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7034 |
