Hi All,
Just wondering if we may have a little problem with our splashback and rangehood. The electrician has fitted the rangehood 100mm higher than the top of the splashback. So the splashback goes along under the overhead cabinets in one piece and then there will be a 100mm gap from top of splashback to rangehood as if he sat it on top of SB it would be too low.
Is this a problem that plaster will be under the RH?
Should the glass be taken up behind the RH to the roof maybe?
Thanks.
