Browse Forums Kitchen Corner Re: Cool Room instead of Pantry/Fridge 21Feb 08, 2008 7:51 pm I'm using subterraininan pipes to help cool the whole house. See https://forum.homeone.com.au/viewtopic.php?t=1790 for more details.
Basically it's a bunch of PVC pipes that are placed just under the house. The air flow is from outside, through the earth tubes and into the house. There are solar chimneys at the top of the house that, as the sun shines on them, draws air through the house and up through the chimneys. All using only the sun's energy. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Cool Room instead of Pantry/Fridge 22Feb 09, 2008 11:54 am ![]() Basically it's a bunch of PVC pipes that are placed just under the house. The air flow is from outside, through the earth tubes and into the house. There are solar chimneys at the top of the house that, as the sun shines on them, draws air through the house and up through the chimneys. All using only the sun's energy. Wow, great idea! Re: Cool Room instead of Pantry/Fridge 23Feb 09, 2008 12:33 pm Thanks, I think so. With all the measures, the objective is to keep the house between 20 to 26 degrees Celcius all year round without any air-conditioning or heaters. (It's allowed to go down a bit below this after 10 pm on a cold winters night.) I'll let you know how I go. Demolition August 2009, Construction Started September 2009, Completed December 2010 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 1696 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 2741 ![]() We are building a new house and it will be the first house we have that has a butlers pantry (existing has just a walk in pantry). The main thing we want to do is to have… 0 18105 |
