Browse Forums Kitchen Corner Re: Cool Room instead of Pantry/Fridge 23Feb 09, 2008 11:33 am Thanks, I think so. With all the measures, the objective is to keep the house between 20 to 26 degrees Celcius all year round without any air-conditioning or heaters. (It's allowed to go down a bit below this after 10 pm on a cold winters night.) I'll let you know how I go. Demolition August 2009, Construction Started September 2009, Completed December 2010 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6277 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5200 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44070 |
