Browse Forums Kitchen Corner 1 Oct 11, 2011 6:57 pm Just wondering if anyone has had experience with a Vinyl Wrap & Pyrolytic Ovens A bit concern that the high heat used in Pyrolytic cleaning will undo the glue on the Vinyl Wrap. I bought a westinghouse oven (linked below) and not sure if it's safe to use the cleaning program! http://www.westinghouse.com.au/Product? ... EB23D34A0D My Baby Hartley initial deposit 7th Aug'10 Signed contract 4th Dec'10 site start as per contract 25th May'11 slab pour 22nd Jun'11 Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 2Oct 12, 2011 11:43 am If you have vinyl wrap doors then the kitchen company should have fitted metal heat deflector strips around the oven. If they have done this then you shouldnt have a problem. If they havent then you could have a problem even with standard cooking temps! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 3Oct 12, 2011 2:17 pm We've just bought a Fisher & Paykel Pyrolitic oven and will have vinyl wrap with our new kitchen cabinets. We were told by both the store we bought the oven from and our cabinet maker that we should be fine - the pyrolitic ovens have a double cavity (as opposed to the single cavity of a convential oven) and special seals (rather than just rubber) that prevent the heat escape when on the cleaning mode and won't warp the cabinetry. If your concerned, contact the manufacturer and check with them. Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 4Oct 12, 2011 4:25 pm Mrs Mac We've just bought a Fisher & Paykel Pyrolitic oven and will have vinyl wrap with our new kitchen cabinets. We were told by both the store we bought the oven from and our cabinet maker that we should be fine - the pyrolitic ovens have a double cavity (as opposed to the single cavity of a convential oven) and special seals (rather than just rubber) that prevent the heat escape when on the cleaning mode and won't warp the cabinetry. If your concerned, contact the manufacturer and check with them. But what about standard mode?? Almost every vinyl wrap supplier suggest heat shrouds around the oven. They are purchased with the vinyl doors and fitted before the oven goes in. The biggest problem is when you open the door. A gust of hot air rushes out of the oven and this oven time damages the doors! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 5Oct 13, 2011 4:56 pm Thanks. @CuttingEdgeKitchens, i don't think i have metal heat deflector strips in the oven cavity. Do you know if this is a fairly easy item to install? i.e. something you can just nail/glue on? @Mrs Mac, hope it goes well with your cupboards too! i can't see any manufacturer disclaimers on Vinyl Wraps so hopefully this won't be a problem for me either! My Baby Hartley initial deposit 7th Aug'10 Signed contract 4th Dec'10 site start as per contract 25th May'11 slab pour 22nd Jun'11 Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 6Oct 13, 2011 5:16 pm S_Loke Thanks. @CuttingEdgeKitchens, i don't think i have metal heat deflector strips in the oven cavity. Do you know if this is a fairly easy item to install? i.e. something you can just nail/glue on? @Mrs Mac, hope it goes well with your cupboards too! i can't see any manufacturer disclaimers on Vinyl Wraps so hopefully this won't be a problem for me either! Yep very easy to install. They just screw on. You could try a company called Tesrol Joinery. They sell them! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 8Oct 17, 2011 7:54 pm Thanks all for the advise. Will have at look at these! My Baby Hartley initial deposit 7th Aug'10 Signed contract 4th Dec'10 site start as per contract 25th May'11 slab pour 22nd Jun'11 Re: Vinyl Wrap & Pyrolytic Ovens - will the heat damage the 10Oct 19, 2011 7:30 pm CuttingEdgeKitchens S_Loke Yep very easy to install. They just screw on. You could try a company called Tesrol Joinery. They sell them! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11254 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17007 Vapour permeable wraps are recommended for any climate and main think it is allow walls to breath (i.e. remove water vapour) while at the same time, providing protection… 4 9763 |
