Browse Forums Kitchen Corner 1 Oct 03, 2011 2:42 pm Hi All, Building a new house, the kitchen glass splash-back has been installed and we have a PCI coming up very soon. The splash-back is meant to be 650mm high, but after having a look at the installed splash-back, it is at-least 4-5mm short at the bottom and has been filled with sealant/glue( 4-5 mm thick glue). The splash-back is 10mm short horizontally. Does anyone know what the standard and tolerances are with regards to the size of splash-backs. Re: Glass splash-back standards and tolerances 2Oct 04, 2011 12:51 pm 4-5mm is quite standard but 10mm short is to much. I wouldnt accept it. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Glass splash-back standards and tolerances 3Oct 04, 2011 3:34 pm Standards and tolerances states: "Departures from the documented set out for service rooms such as bathrooms, toilets, laundries, kitchens etc are defects if they exceed L/200 or 5mm whichever is the greater, where L is the documented dimension" From this I take it that it must be within 5mm (as 650/200=3.25) I don't see that a 4-5mm bead of sealant is an issue, but if it is 10m short then that would be problem IMO. Re: Glass splash-back standards and tolerances 4Oct 04, 2011 5:48 pm Thank you guys for the vaulable information provided. I had it measured today the gap between the ceaserstone and the glass splashback is 6 to 7 mm. I have attached the photos below http://imageshack.us/photo/my-images/11 ... back1.jpg/ http://imageshack.us/photo/my-images/63 ... back2.jpg/ http://imageshack.us/photo/my-images/56 ... backi.jpg/ is 6-7mm acceptable???, i personally do not like that big bead of glue at the bottom. Re: Glass splash-back standards and tolerances 5Oct 05, 2011 2:43 pm abraham is 6-7mm acceptable???, i personally do not like that big bead of glue at the bottom. I wouldnt be happy with 6-7mm of silicone. 4-5mm max Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Our Bondi Greenwall was impressive from day one with advanced lush plants to provide a wow factor to this recently renovated living area. The boundary was less than 1… 0 15303 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5152 |
