Thanks!
I am with you now.
Is there anyway of reconfigering the windows / doors so that you can move the door to allow the kitchen to be bigger??
Browse Forums Kitchen Corner Re: Kitchen layout - help please 21Sep 30, 2011 10:21 am DarlaDark Hi CuttingEdgeKitchens. To make it a U would mean that the cupboards would use 1200 of the 1900 distance which leaves only 700 between island and fridge wall, which is far too small. I've moved the island out now so that it's 900 from the fridge wall cabinets and also leaves enough space for the door to swing into the kitchen. Thanks! I am with you now. Is there anyway of reconfigering the windows / doors so that you can move the door to allow the kitchen to be bigger?? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen layout - help please 23Sep 30, 2011 10:57 am Do you have the measurements of the sink window and walls on either side?? I might have an idea but it depends on those sizes Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen layout - help please 25Sep 30, 2011 12:47 pm How about moving the door completly? I havent seen you full plans so I am not sure if this would work, but you could have a galley kitchen with a huge attached island bench with the door at the end. Here is a quick plan, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen layout - help please 26Sep 30, 2011 12:47 pm There is 1300mm between tops in that plan. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchen layout - help please 27Sep 30, 2011 12:59 pm Unfortunately we can't do that because we just replaced the door and added a window to that wall so we'd have to change it again which would be too much cost. Thanks for your help though You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 17323 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 21244 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6346 |
