Browse Forums Kitchen Corner 1 Aug 12, 2011 9:56 am Is $5,500 including gst a reasonable price for standard caesarstone with the following inclusions:
6m x 1m (4m x 1m + waterfall ends) 2.46m x 0.65m undermount sink cutout Re: Caesarstone benchtop quote 2Aug 12, 2011 10:22 am works out to be $725m2 ish not sure if that will help anyone. Sounds like a lot though to me. Re: Caesarstone benchtop quote 4Aug 12, 2011 10:53 am The quote is for any colour in the standard range. Re: Caesarstone benchtop quote 5Aug 12, 2011 11:18 am What thickness and will the waterfalls be mitred? Waterfalls take alot of extra time and cost more. They do look great though! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Caesarstone benchtop quote 6Aug 12, 2011 11:21 am CuttingEdgeKitchens What thickness and will the waterfalls be mitred? Waterfalls take alot of extra time and cost more. They do look great though! Yes, it includes mitred waterfalls. Thickness is 20mm, but with 60mm apron on all visible sides. Re: Caesarstone benchtop quote 7Aug 12, 2011 11:51 am Testedbytime CuttingEdgeKitchens What thickness and will the waterfalls be mitred? Waterfalls take alot of extra time and cost more. They do look great though! Yes, it includes mitred waterfalls. Thickness is 20mm, but with 60mm apron on all visible sides. So its a 60mm thick top(20mm plus the mitred front edge). Caesarstone is only available in 20mm and limited 30mm. Any other thickness is either doubled up or mitred. With a 60mm top everything would be fully mitred. I am assuming you have an island unit and the top would over hang between 250-300mm. Remember that the caesarstone needs to be returned back into the overhang on both waterfalls and the underside of the top. This adds alot of caesarstone and labour to the cost and would be one of the reasons your top is so expensive. I would say the quote is about right. You could drop $1800 of you quote easily with a few changes! It wouldnt look as good though. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Caesarstone benchtop quote 8Aug 12, 2011 11:56 am CuttingEdgeKitchens Remember that the caesarstone needs to be returned back into the overhang on both waterfalls and the underside of the top. This adds alot of caesarstone and labour to the cost and would be one of the reasons your top is so expensive. You might want to check your stonemason does include this in his quote. There are quite a few forum members whose c'stone has not been returned back. The front of their benches are simply a mitred front - and you can see the substrate underneath when looking up. Mine stonemason did "box" in my benches - we have 80mm waterfall and apron - so you can not see any underneath of the stone. Some things are worth waiting for. Re: Caesarstone benchtop quote 9Aug 12, 2011 1:23 pm kyton CuttingEdgeKitchens Remember that the caesarstone needs to be returned back into the overhang on both waterfalls and the underside of the top. This adds alot of caesarstone and labour to the cost and would be one of the reasons your top is so expensive. You might want to check your stonemason does include this in his quote. There are quite a few forum members whose c'stone has not been returned back. The front of their benches are simply a mitred front - and you can see the substrate underneath when looking up. Mine stonemason did "box" in my benches - we have 80mm waterfall and apron - so you can not see any underneath of the stone. Exactly. It doesnt matter so much on the small overhangs (20mm) but on the large overhangs it should return back. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Caesarstone benchtop quote 11Aug 12, 2011 1:56 pm kyton Mine stonemason did "box" in my benches - we have 80mm waterfall and apron - so you can not see any underneath of the stone. Thanks for that. Any chance I could see a photo of yours? Just so I can show it to my stonemason. Re: Caesarstone benchtop quote 12Aug 12, 2011 2:13 pm Is Plywood Underlayment & Brackets the correct way to create support of overhangs between 300mm and 457 mm? http://www.uhny.com/pdf/caesarstone_tech_datasheet.pdf Re: Caesarstone benchtop quote 16Aug 15, 2011 1:28 pm Yes my overhang was done that way. My working side of the bench as well as my two smaller side benches are finished off like diagram A as they sit flush against the substrate of the cabinetry from memory. Some things are worth waiting for. hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20920 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14324 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12408 |
