Browse Forums Kitchen Corner Re: Pros and Cons on handle-less cabinets/cupboards please 21Aug 16, 2011 3:09 pm A little off topic but... is it a massive cost difference to get the aluminium strips, say compared to, high quality handles??? Sensational Kitchens CuttingEdge Kitchens!! I see your location is in Sydney, wish you were in Melbourne. Re: Pros and Cons on handle-less cabinets/cupboards please 22Aug 16, 2011 3:37 pm rocketship A little off topic but... is it a massive cost difference to get the aluminium strips, say compared to, high quality handles??? Sensational Kitchens CuttingEdge Kitchens!! I see your location is in Sydney, wish you were in Melbourne. Thank you. The aluminium strip handles do cost more than a high quality handle as there is a bit more work in them and cost about the same as an expensive handle. I dont really like them. The corners are always sharp.(If you round them off they look terriable) Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12047 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61375 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 |
