Browse Forums Kitchen Corner 1 Jul 11, 2011 5:54 pm Hi, I'm doing the apparently maligned but practical "window behind the cooktop" thing, but I'm using uPVC framing everywhere in the house. My kitchen designer raised concerns that having a cooktop so close to a uPVC frame, even if it's induction, may be a fire hazard and thus not compliant. Does anyone know if this is the case? What's the minimum clearance I should have then? Thanks! Newtown rebuild: https://forum.homeone.com.au/viewtopic.php?f=53&t=48977 Re: uPVC windows and cooktops 3Aug 26, 2011 3:41 pm FYI for any interested people, according to this: viewtopic.php?p=706885 200mm suggested clearance from non-fire-retardant surface. My current kitchen plans have 170mm clearance, with 30mm edge to PVC, I should be in the clear. Newtown rebuild: https://forum.homeone.com.au/viewtopic.php?f=53&t=48977 3 4167 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10923 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3830 |
