Browse Forums Kitchen Corner 1 Jun 22, 2011 12:06 am Not sure if this is the correct forum. Wondering if there are any issues with having a small bar fridge inside a closed door cabinet as part of a kitchenette and sink. May concern is about ventilation around the fridge if it is enclosed Re: Kitchenette and Bar fridge 2Jun 22, 2011 7:37 am noki388 Not sure if this is the correct forum. Wondering if there are any issues with having a small bar fridge inside a closed door cabinet as part of a kitchenette and sink. May concern is about ventilation around the fridge if it is enclosed If you buy a model that is made to be intergrated then it is fine! I have intergrated many fridges and bar fridges without a problem. They have all come with the manufacturers intergration kit. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Kitchenette and Bar fridge 3Jun 22, 2011 9:43 am We have done quite a few of these in office fitouts and generally we have used the fisher & paykel mini bar fridge, and integration kit, with a vent in the kick. No problems so far, you may need to refer t the manufacturer's spec for their recommended ventilation minimum Re: Kitchenette and Bar fridge 5Jun 24, 2011 5:00 pm Put a vent in the door - solved! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Please suggest a solid quality swivel bar towel holder in bathrooms & bedrooms from… 0 3122 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7536 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10033 |
