I want one of these
But am unsure if it will fit in the microwave cut out
Browse Forums Kitchen Corner Re: How big is a standard microwave cut out?? 6May 25, 2011 10:16 pm Matt's Brando: viewtopic.php?f=31&t=46340 Started March 30th 2011 PCI July 15th Re: How big is a standard microwave cut out?? 11Jun 02, 2011 11:41 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: How big is a standard microwave cut out?? 12Jun 02, 2011 12:44 pm The installation guide here https://portal.bsh-partner.com/portal%2 ... LFRAME.HTM Says that the cavity should be min 450mm internal height, 568mm (560+8mm) internal width and 5500mm internal depth. PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10256 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5498 2 5503 |
