Browse Forums Kitchen Corner 1 May 20, 2011 6:44 pm hi, just after peoples opinions, I have a U shape kitchen, benchtops measures 4.473m2. bench top panels measuring 1980x.600mm, 1500x.600mm,2650x.900mm Ive decided im going with the bunnings think solid bench surface pritty much exact same as corian. the bench tops supplied to me is $2674 in 24mm edge. bunnings have a prefered installer which charges a flat rate of $795 to install the bench tops, Keeping in mind the bench tops are already made to exact size, factory mitered joints all hardware to install including the tooling for a router for cutting out sink and cook top. is $795 a bit of a hefty price to install? can any one recommend someone in perth that could do it for a cheaper price? Thanks inadvance. James That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8648 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12929 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31283 |
