Browse Forums Kitchen Corner 1 May 16, 2011 6:28 pm Have a 1500x200mm zenolite panel that I'm trying to stick behind the kitchen sink to the painted gyprock. It has 6mm clearance each end and 3mm top/bot as per the instructions. Back of panel has 12x1.6mm double sided tape and 6mm beads of a silicon adhesive (Selly's liquid nails), also as per instructions. The ends and one spot in the middle are sticking fine, but large chunks of the rest just keep lifting and flexing a couple of mm, I just can't get it to bond. What to do? leave it and hope it sticks later? (only 30 min at this stage). Re: Help! Zenilite SB won't stick down! 2May 16, 2011 7:31 pm Acrylic can be quite elastic and try very hard to find it's own equilibrium. Does the liquid nails appear to be sticking to the acrylic but just stretching? If so I would recommend that it all just be pressed up against the wall as much as possible so that when the silicon goes off it will be holding he splashback in the desired position. Cheers, Earl Re: Help! Zenilite SB won't stick down! 3May 16, 2011 9:27 pm Strumer Acrylic can be quite elastic and try very hard to find it's own equilibrium. Does the liquid nails appear to be sticking to the acrylic but just stretching? Yes Quote: If so I would recommend that it all just be pressed up against the wall as much as possible so that when the silicon goes off it will be holding he splashback in the desired position. Will do, thanks Earl. Re: Help! Zenilite SB won't stick down! 5May 18, 2011 10:45 am No worries, I'm glad it worked out for you - would love to see a photo or two of the finished job. Cheers, Earl Re: Help! Zenilite SB won't stick down! 6May 23, 2011 3:22 pm Strumer No worries, I'm glad it worked out for you - would love to see a photo or two of the finished job. Cheers, Earl Hi Earl, all done! very pleased with result, thank you very much for your help and advice. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 100_1426.JPG by lindsay.mathieson, on Flickr Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 100_1427.JPG by lindsay.mathieson, on Flickr Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 100_1429.JPG by lindsay.mathieson, on Flickr Re: Help! Zenilite SB won't stick down! 7May 23, 2011 5:15 pm Hey that splash looks great - good job on the install. Thanks for the update, that kitchen looks almost finished and I hope you have lots of happiness with it. Cheers, Earl Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6158 How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28574 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12285 |
