Browse Forums Kitchen Corner 1 Apr 17, 2011 2:37 pm Hello everyone I'm wondering if anyone installed stainless steel pull out pantries. If so was it DIY job or did you get your kitchen company to install it for you? I found some suppliers on the web: www.leksupply.com.au www.tansel.com.au Re: Pull out pantry 2Apr 17, 2011 2:41 pm search.php?keywords=pull+out+pantry&terms=all&author=&fid%5B%5D=16&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search Just a quick search - there are a few threads in there that may be appropriate. Some things are worth waiting for. Re: Pull out pantry 5Apr 18, 2011 1:10 pm I had one. I installed it myself but then again i installed the whole kitchen. Not 100% i would grab one again. When you pulled it out you couldn't really get stuff from both sides you had to reach or walk around it (hope that makes sense). If i was dealing with a small slim pantry again i would probably get a door that could open and slide into the cupboard then have individual metal draws. Basically when you just wanted to grab the cereal out you would open the door like a normal pantry but if you where going to be cooking and hunting down the obscure spice at the back of the draw you would have the door open and tucked away. Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6349 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5202 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44071 |
