Browse Forums Kitchen Corner 1 Jan 03, 2008 4:31 pm I recently stayed in an apartment-style motel, that had a kitchen with cupboards that had shelves that rolled out, rather like drawers. But they weren't really drawers, more like shelves with metal 'barriers' to stop things from, obviously, falling out.
I have tried to find such a thing but with most kitchen shops closed for the holiday season, it's proving an elusive task. I have also tried to describe this concept to others but, as they haven't seen it (well, apart from the two friends who were also holidaying with me!) , It's hard to pass on the concept successfully. Anyone know of this kind of thing in a kitchen? Fiona Re: Cupboards with Roll-Out Shelves 2Jan 03, 2008 4:59 pm something here?
http://www.blum.com/au/en/index.php Re: Cupboards with Roll-Out Shelves 3Jan 03, 2008 5:00 pm I know what you're talking about. I've seen them around but I can't for the life of me remember where. Some catalogue. Or magazine. Or something. ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But here's a link to start you off. http://www.thestorageshop.net.au/kitchen.html I'd assume most kitchen type places would have them. [sneakersss] Re: Cupboards with Roll-Out Shelves 5Jan 03, 2008 5:35 pm Bec…..similar to this?
These have been around for quite few years now, wonderful invention for the kitchen! TOP ONE! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They come in better styles now, and an array of uses! ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Cupboards with Roll-Out Shelves 6Jan 03, 2008 5:44 pm YSSIM,
There is a pic on The Storage Shop's website of EXACTLY what I'm talking about. The Storage Shop calls them "Full Extension Drawers" and are designed to be in cuboards. Hopefully I can find them somewhere in MLB. Thanks very much! Fiona Re: Cupboards with Roll-Out Shelves 8Jan 03, 2008 6:13 pm Fiona….got you!
Sorry….didn’t give thought to the basic designs…… ![]() Plus I didn’t read the posts properly, I thought Bec posted the question……now where my glasses? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Cupboards with Roll-Out Shelves 9Jan 03, 2008 10:17 pm ![]() YSSIM, There is a pic on The Storage Shop's website of EXACTLY what I'm talking about. The Storage Shop calls them "Full Extension Drawers" and are designed to be in cuboards. Hopefully I can find them somewhere in MLB. Thanks very much! Fiona Oh yes, those! I like the idea of them and want to use them for my kitchen, too, to maximise use of the space. And be more organised. ![]() Not entirely sure what look you are after but check out and investigate the 'rationell' series from ikea. They look pretty nifty to me. http://www.ikea.com/au/en/catalog/categories/series/08078/ [sneakersss] Re: Cupboards with Roll-Out Shelves 10Jan 08, 2008 9:36 pm I have them in my present kitchen, great stuff but i still feel draws are better. the next house will have drawers in the kitchen. I think they can be easily retrofitted. check the blum or heittich websites as most manufacturers source the hardware from them.
good luck! Re: Cupboards with Roll-Out Shelves 11Jan 09, 2008 6:16 pm if you really want them you could probably just install draws in your standard cabinets.
You can get draw kits for 400 through 900 cab sizes which is base, runners/sides, back plate, you could easily add a laminate front on (use back plate as a template) then using the small fat screws (euro screws i think they are called) mount into the standard 32 drillings you have down the side for shelf/hinge mounting. You might want to put the draw kit back one hole on the runner that mounts to the cab (the draw runners will have like 3 holes front and back). Even with out the standard 32 holes down the side of the cabs you could install it just takes a little measuring up. The biggest issue i can see is you will need the hinges that open the door fully not just approx 100 degrees. If you go the DIY option it might not be to bad but generally buying those retail storage solution kits are very much overpriced i have found. Personally i think draws are a better solution because you dont have to open a cupboard then open a draw, draw fronts can be made as nice kits so come as a pack of three, our new place the bottom and top draws have three sides with a nice bevel where as the middle only has it on the sides. Re: Cupboards with Roll-Out Shelves 12Jan 09, 2008 10:18 pm ![]() I know what you're talking about. I've seen them around but I can't for the life of me remember where. Some catalogue. Or magazine. Or something. ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But here's a link to start you off. http://www.thestorageshop.net.au/kitchen.html I'd assume most kitchen type places would have them. These type of pull out pantries are much better when the drawers are attached to a front door plate. This way you just pull one thing open and everything is accessible. Demolition August 2009, Construction Started September 2009, Completed December 2010 My bathroom had this same layout. I put the toilet roll holder on the shower screen side - silicone it to the glass. 4 4678 Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 2799 ![]() Thanks for the response and suggestion. The other side isn’t fixed. It’s comes out as well (you can see the dirt markings as to how far the window can be pushed… 2 7832 |
