Browse Forums Kitchen Corner 1 Mar 28, 2011 6:49 pm After getting so much inspiration from this forum (as a lurker ), I thought I should post some photos and details about my pretty-close-to-being-finished kitchen renovation.
I've got a late-1970's 2 bedroom villa in suburban Melbourne. I've been here for about 4 years now and the kitchen was the last area that needed renovating. It's a pretty good size (3.6m x 3.8m), but was the original 'vintage' one from when the house was built. It had raw chipboard carcasses, skinny benches, a white laminate top that had seen better days and wood veneer doors (although these seem to be back in fashion now!). Here's the before shots: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After much consideration about whether to lay a new floor, I decided to get the original combination pine (baltic/cypress) floorboards polished instead. The rest of the floors had already been done (hallways, lounge and dining). So the first job was to pull up the vinyl tiles on the kitchen floor. What a pain! Most of it came up, but some of the black backing paper stuck to the floor and the glue left big swirl marks on the boards. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Next thing was to remove the old fridge cavity wall and built-in pantry and then widen the doorway between the kitchen and adjoining dining room. Luckily the wall wasn't load-bearing so we were able to do this as a DIY exercise. Before: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ During: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ More to come including installing a cavity sliding door in the other doorway, first fix electrics & plumbing, initial sanding of the floor and THEN the kitchen installation! Re: Kitchen Reno - Before, During & (eventually) After 2Mar 28, 2011 8:05 pm Plasterboard on the new doorway: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Opening up the wall to install a cavity sliding door: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Floor about to be sanded: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Getting the vinyl glue off was quite a challenge: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The sanding process used up 18 sanding belts: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The floor after being punch-nailed and filled with putty: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The floor after being sealed - ready for installation of the kitchen! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Kitchen Reno - Before, During & (eventually) After 4Mar 28, 2011 9:31 pm My new kitchen was built and installed by Bam's husband (Custom European Cabinets). The specs are as follows:
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The plastering and cornices will be done on Thursday and then plumbing, electrical, lighting and painting on the weekend! I'm also doing a tiled splashback (Takaota 'Ash Gloss' 300 x 100 ceramic tiles). I'll post some more pics once everything's done and installed Re: Kitchen Reno - Before, During & (eventually) After 5Mar 28, 2011 10:05 pm wow what a transformation - gorgeous cabinets, and aren't the floors fabulous! well done! A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17208 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98765 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81821 |
