Browse Forums Kitchen Corner 1 Mar 22, 2011 5:31 pm We currently have a 900 slimline gas cooker, so only 4 burners but nicely spreadout. with our kitchen reno we are looking at getting another 900, but note that many come with the"wok" burner. Do people only use the wok burner for wok cooking? may sound dumb but we cook steak at a very high heat on our cooktop, so would you use the wok burner to achieve this also? and for those who have the wok burner in the middle (which seams to be most) does it then prevent you from using the other burners? thanks! Re: 900 gas cooktops 2Mar 24, 2011 8:07 pm We've got a 90cm gas cooktop and the centrally placed wok on medium flame matches our 30cm frypan just right We find the wok and larger pans do tend to overlap when used together. It's not impossible to use them at the same time but you got to be a bit careful. Re: 900 gas cooktops 3Mar 24, 2011 8:12 pm We just got a new Omega 900 freestanding oven cooktop and find that we use the centre wok burner most for wok cooking but the frypan works well with enough room for the saucepans too. works for us. Built an Aquarius 32 by Cosmopolitan Homes in Sydney Re: 900 gas cooktops 4Mar 27, 2011 1:32 pm theyetti We've got a 90cm gas cooktop and the centrally placed wok on medium flame matches our 30cm frypan just right We find the wok and larger pans do tend to overlap when used together. It's not impossible to use them at the same time but you got to be a bit careful. Good question OP, theyetti / fisser, could you pls post a piccy (camera-fone even would be great) of pan / wok on central burner showing large-ish pot on another burner ?? Thanks, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 4 10824 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3667 |
