Browse Forums Kitchen Corner Re: 900 gas cooktops 4Mar 27, 2011 1:32 pm theyetti We've got a 90cm gas cooktop and the centrally placed wok on medium flame matches our 30cm frypan just right We find the wok and larger pans do tend to overlap when used together. It's not impossible to use them at the same time but you got to be a bit careful. Good question OP, theyetti / fisser, could you pls post a piccy (camera-fone even would be great) of pan / wok on central burner showing large-ish pot on another burner ?? Thanks, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 4 10821 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3656 |
