Browse Forums Kitchen Corner Re: Caesarstone benchtops- overhang of 40 cm okay? 2Feb 20, 2011 9:39 am I can't say that surprises me because it's VERY heavy. We have a 40cm overhang for our breakfast bar but have a waterfall end to support it. Re: Caesarstone benchtops- overhang of 40 cm okay? 3Feb 20, 2011 10:09 am jtnru I am having a caesarstonebechtop with an overhang of approx 40cm on one end and along one side. My cabinet maker says I will need a support post in the corner - anyone else needed to do that??? Yes unless you want the stone to crack Re: Caesarstone benchtops- overhang of 40 cm okay? 4Feb 20, 2011 1:16 pm I was told that waterfall ends don't provide enough support. But then again this probably depends on the length if your island... Caesarstone benchtops- overhang of 40 cm okay? 6Feb 20, 2011 4:49 pm blueblueblue I was told that waterfall ends don't provide enough support. But then again this probably depends on the length if your island... I don't know how true this is? My island is 4000 x 1200 and has waterfall edges. The only other "support" there is is the actual cabinetry underneath. My kitchen maker has been in business for close to thirty years so I trust him implicitly. Some things are worth waiting for. Re: Caesarstone benchtops- overhang of 40 cm okay? 7Feb 21, 2011 12:43 am Maximum unsupported overhang for ceasarstone bench tops is 300mm. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Caesarstone benchtops- overhang of 40 cm okay? 8Feb 27, 2011 4:27 pm What are the "support" options chippy? Re: Caesarstone benchtops- overhang of 40 cm okay? 9Aug 12, 2011 2:23 pm http://www.uhny.com/pdf/caesarstone_tech_datasheet.pdf recommends
Plywood Underlayment & Brackets for overhangs between 300mm and 457 mm? See page 14 http://www.uhny.com/pdf/caesarstone_tech_datasheet.pdf Re: Caesarstone benchtops- overhang of 40 cm okay? 11Jan 29, 2012 12:30 am quantum quartz manual says: All the overhangs provided for the breakfast bar or any top should be properly supported with brackets. Rule of thumb is that any overhang exceeding 200mm shall require 10mm thick 70 mm wide steel bar placed underneath the top. However, if 40mm thick laminated edges are used then the piece pasted to the top can extend the whole width of the over hang to take some stress placed on the overhangs. If the overhang is less than 400mm then the general practice is to provide a support base made up of timber and the brackets placed approximately 500mm apart. All overhangs exceeding 400mm should be supported with proper metal legs. The brackets should be fastened to a backer plate, which is secured with the cabinet with screws. Re: Caesarstone benchtops- overhang of 40 cm okay? 12Jan 30, 2012 4:48 pm My benchtop is 4m long and I have a 380mm overhang and no supports, apart from the waterfall ends. I've got 40mm stone . my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7899 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3896 |
