Browse Forums Kitchen Corner Re: Stone benchtops cost? 2Feb 08, 2011 12:02 pm kels How much do caesarstone (or similar) benchtops cost roughly per square metre do you think? Has anyone recently had just lone benchtops installed for a kitchen bench of around 1.5x 3m? Cheers Kels, we paid something like 5K for it.. not sure about the size but it sounds similiar Re: Stone benchtops cost? 3Feb 08, 2011 9:09 pm Below is the price list for Ikea caesarstone: This is just the cost of the benchtop, plus installation and site check for about $600 and other charges such as cut out for cooktop and sink, etc. Re: Stone benchtops cost? 5Feb 20, 2011 11:35 pm kels How much do caesarstone (or similar) benchtops cost roughly per square metre do you think? Has anyone recently had just lone benchtops installed for a kitchen bench of around 1.5x 3m? Cheers About $2000.00 but all is about the joining where does it go. Pazstone may give you a good price then again I don't know where in Australia you live Re: Stone benchtops cost? 7Feb 21, 2011 6:34 am CC101 that ikea price seems much cheaper then what private stone kitchen people charge Not so if you add Quote: and other charges such as cut out for cooktop and sink, etc. Re: Stone benchtops cost? 8Feb 21, 2011 9:18 pm Hi I was just given these quotes- my vanity is 2m long. Caesarstone standard colour- $1140. Nougat is extra but not sure how much more. Quantum Quartz standard colour- $890 Floor stock selection- $750 Lucky for me what I wanted they had in floor stock! Hope that helps Donna Re: Stone benchtops cost? 9Mar 10, 2011 7:21 am What determines the price of engineered stone 1) size of tops - engineered stone only comes in 3000mm x 1400mm slabs 2) colour - there is standard deluxe and premium 3) thickness - you can have anything 20mm - 200 mm 4) edge profile - aris, pencil round, bullnose, sharks nose etc 5) waterfall ends - should be mitre jointed to your tops for a seemless join 6) undermounted sinks - again more work polishing, installing etc 7) joins - any good stonemason will not put joins half way through a bench If you have a kitchen with an island it a bench that is 900mm wide generally you are going to require two slabs of stone as 900+600 is greater than 1400mm so is impossible to get out of one slab Average kitchen based on two runs of 600mm wide benches at upto 3000mm each and a island bench upto 1200mm wide in 20mm from standard colours will cost you about $3000 installed not including waterfall ends and undermounted sinks And about $2000 installed for a run of upto 800 wide and a run of upto 600 wide or two runs of 600 width If you can get it out if one slab ab 5) travel 5) the reason slabs are included in the quote is because often the offcuts from jobs are not usable for other jobs. When youre ordering a small job, there *may* be some cut… 3 2125 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6711 |
