They dissolve away as you use them
They can also dull shiny surfaces - so you must be careful
There are a few brands here is one
http://www.chux.com.au/the-chux-range/c ... eaner-8pk/
Browse Forums Kitchen Corner Re: How do you clean your kitchen cupboards 21Feb 14, 2011 9:03 am ourhome Wow I have never used this magic eraser. On what materials can it be used? How long does the pack last? How it can be used? Sorry for so many questions but I am really excited to know about this product. They dissolve away as you use them They can also dull shiny surfaces - so you must be careful There are a few brands here is one http://www.chux.com.au/the-chux-range/c ... eaner-8pk/ Re: How do you clean your kitchen cupboards 22Feb 14, 2011 10:19 am The same stuff only more expensive Where you are coming from is where you are going to... Re: How do you clean your kitchen cupboards 23Feb 14, 2011 10:54 am Trish ourhome Wow I have never used this magic eraser. On what materials can it be used? How long does the pack last? How it can be used? Sorry for so many questions but I am really excited to know about this product. They dissolve away as you use them They can also dull shiny surfaces - so you must be careful There are a few brands here is one http://www.chux.com.au/the-chux-range/c ... eaner-8pk/ Thanks a lot Trish. Re: How do you clean your kitchen cupboards 24Feb 14, 2011 1:44 pm Trish is right, you do have to wipe over it with a damp cloth to get rid of the residue. I have used it on everything, walls, to get rust off mirrors, small amounts of sillicon of glass. A tradie spilt some straight red cordial on a cs bench and didn't clean it up it was there for at least a weekend and when i got to it it was a huge red stain, magic eraser even got that off (though it did use up alot). If you have it in your mind that it is a sponge and would last as long as one you will be disappointed, it will look like it is ready to throw arter just a few uses but don't, you can use each piece until it no longer exists. I can't say how long that is because it will depend on how hard you press on it and what you are using it on etc. If you get the big block I would suggest breaking off a piece about 4-5cm wide, that seems to be a good size to handle. you might be tempted to go smaller to save it but there is no need as I said because you don't throw it away. Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39468 Hi, Can anyone give me approx. price for overhead cupboards. TIA 0 16553 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6625 |
